I had to cut about 3/4" off the Z-bar width to get a Lakewood installed in a 70 gTx. Other than that and grinding the tunnel lip it was pretty straight-forward.
The things weigh a ton and if you dial it in you'll probably be installing it more than once. So, do some push ups to get ready (or do what I did and use a transmission jack to do the lifting).
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
