Sounds like what some guy was doing a long while ago, had some high frequency box that would wreck havoc with the ignition system so the engine ran bad. He did it at the starting line and was easy to catch him using it. I imagine it would have been less obvious down the track at the end. It worked very well against the solid plug wires everyone was using at that time.
