if you are just removing the arms then it is not too bad, though my regular impact gun would not brake the bolts loose. (IR 231 about 325 ftlbs) The bushing had caused some binding issues and would not allow the nuts to turn. I wound up borrowing a IR Titanium (800 ftlbs) and it removed the bolts.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
