I have a drop base with the foam lid. Both are new, tried to get them to work with a very tall single plane couple of years ago but was too tight. Ended up switching to a dual plane dual carb setup, and it came with a filter. These have been sitting on the shelf since then. $50 plus freight.
Stephen PM me here
70 Go Mango Charger RT White Vinyl Top 18 Spline 4 speed Lakewood Scatter Shield/ Centerforce DF Clutch, Hydraulic bearing 505 Stroker, dual 600's, hyd roller cam - 525 hp, 640 torque
