My car has done this same thing since I converted it to front disc. I used front disc setup off of a 80's diplomat. Spindles, rotors, calipers, and a master cyl from a 90's dodge ram truck I believe. The fronts just dont turn free when its jacked up. I dont think it is hurting my E.T.'s but I could be wrong.
If it's a front drum brake master, that may be the problem. And if there is enough resistance, and they grab or one does, think of the possibilities.
It is a aluminum master off a 94 Ram with disc brakes. It is certainly drag from the pads. I hope no one has wheel bearings that tight or you are gonna have some major issues. I dont think you could get anything in the 90's with drum brakes! The master cyl. rod is correct length and not pushing the piston on the master.
67' charger 499 RB
10.57 at 127
