Quote: My car has done this same thing since I converted it to front disc. I used front disc setup off of a 80's diplomat. Spindles, rotors, calipers, and a master cyl from a 90's dodge ram truck I believe. The fronts just dont turn free when its jacked up. I dont think it is hurting my E.T.'s but I could be wrong.
If it's a front drum brake master, that may be the problem. And if there is enough resistance, and they grab or one does, think of the possibilities.
