mopardude - that looks nice
Was that piece for the recess pre-maid? If so, where did you find it?
thank you.
my friend made the recess himself... there is one available at tanks inc, like previously stated, however be careful, i think it comes as shown, a pre-drilled hole for their style of fuel pump mount/top plate. maybe you can order one from them with the holes drilled in it to use the pump kit of your choice?
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
