Quote: Not sure what the brand was but I am in the process of doing one in a 67 GTX right now. I mounted the pump but due to it sticking up I am using a foam bumper on top of the tank for clearance, I'm using the 1/2 inch foam matt for Tractor Supply and will probably double it. Using Summit screw type fittings. I swapped the regualtor toa return style and still have to finish the plumbing at the carbs and run the return line. I think all the final fittings came in Friday so I should be able to finish it Monday.
That's from Tanks Inc. I bought that as well as their recess so the tank would sit flush against the trunk floor. I just saw they are going to be releasing tanks with recesses and baffles built in for A/E-bodies.
