Quote: I suggest you re-read the thread because what I said is that
I did and this is what you said. So by your own words you said I will check it right now. So dont be to quick to tell me to re-read as I am only trying to help. I wont complain because the pay is so good.
Quote: I tried blocking off the EGR before I did the rebuild but I'll try it again. I'll check the vacuum again. I assumed it was doing that because the timing was off but I shouldn't assume. I'll check it again right now.
