If you can ..get the steering colume also..its most likley better than the one in your car .err What are you putting it in ??...Mine is in my 1956 Plymouth and was the best and easiest install..car rides great and straight ,and stops nicley with the disc brakes..take the master cyinder and porportion valve also.. the hardest thing for me were the motor mounts for the 440.good luck
