I guess ALL the manufacturers are wrong. Why have a proportioning valve at all ? So it evens out the pressure from the front to the rear. Hydraulics, Closest to the first point of contact.
Yes If not it will always hit fronts first. Since they are the closest to the M/C
What? Someone has no idea about hydraulics here.
No, in an all drum setup you do not need a proportioning valve.
Cause when you hit the brakes the master cyl applies pressure to the rears first, its designed that way. Wont need a prop vale until disc brakes are added. All the 4 wheel drum brake cars had a junction block, not a prop valve.
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
