Re: 2011 Durango- brake light on dash coming on
[Re: Golden-Arm]
#1739731
01/27/15 03:03 PM
01/27/15 03:03 PM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
low fluid, excess wear in pads/rotors, malfunctioning abs system, proportioning valve hanging up. check the codes, using the plug under the steering column.
2011 had several recalls, for brake issues, on durangos.
Is the code something that can be checked without going to the dealer?
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
