low fluid, excess wear in pads/rotors, malfunctioning abs system, proportioning valve hanging up. check the codes, using the plug under the steering column.
2011 had several recalls, for brake issues, on durangos.
"When Tyranny Becomes Law, Rebellion Becomes Duty"
