Quote: It is mounted the same way. Someone makes a repro of the sharktooth, but it isn't cheap and i think it's made of a cheaper plastic.
Sort of right, the originals were injection molded from ABS plastic, the reproductions are cast in a two part resin. They look k in pictures but are NOT the same in many respects.
