The orig distributor is a bucks down way to get you down the road reliably. However, the shaft arrangement is sloppy at best. I had all the orig stuff then took the plunge into a digital E curve for my stroker, and never looked back. Rev limiter, vacuum advance, many curves to choose just by turning the pots on the circuit board. The piece appears well made and the timing is rock solid. The car has never run better.
