Re: Dodge Vans in Japan
[Re: poorboy]
#1726380
01/12/15 02:36 PM
01/12/15 02:36 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
To the OP, buy another minivan. Gene
Yeah, a full size is going to suck fuel like you aren't used to, so another mini is probably a better fit. Around here, they are going cheap, too.
Same problem though, gotta make sure the engine hasn't been run dry on oil or water, and the auto trans has less than stellar reputation. Make sure to research which engines are best, some are good, some are less so.
