Ok, I guess I should have went out to the shop and looked under my car. The old memory isn't as good as it used to be.
Apparently the steering arm angle with the ball joint swap from side to side doesn't change the steering geometry? I'll have to keep that in mind.
Did you use the position of the lower ball joint tie rod connection point to determine the height of the rack?
Mike
Mike
69 440 Cuda
71 Dart drag car
70 Duster drag car Best et 9.32, 145.9 mph
2019 Ram 2500 4x4
