here's a pic of the STR-14 with the home made top(see attach).
you'll see the carbs are also mounted on top of 2" spacers.
these are open spacers.
Ramcharger, do you have any pics of how you did the linkage on your STR-14??
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
