Hi Guys,
I found a aftermarket block that had a hair 3" line crack repaired. The crank was in the timing chain area from #1 cam journal down toward the oil pump. the crack wasn't all the way through the block.
I can pick it up cheap... What do you guys think?
It will end up being the home for a 572 race motor.
Mike
