Bucket seats almost always fit. I believe Dakota seats will fit as well.
Watch out for seats with thick back cushions and a leaned back backrest. They will put you real close the the steering wheel. Usually, low back seats where the seat back fits under the rear window ledge give you as much steering wheel clearance as possible, which is usually the biggest issue with modern seats. Gene
