I built a pressure bleeder for work. Basically it's a pressure regulator with the appropriate cap for the master cylinder being used attached by a hose. I top up the master and connect the bleeder, attach an air line and set pressure to about 10psi. Then I go to the right rear and open the bleeder until fluid runs, repeat for the other 3 corners. Check the fluid level after each corner.
Photobucket sucks
