If you do not tow with the truck or carry heavy weight in the back they are fine. But if you do use the truck to do the mentioned things above the rear end will drop and sag. If you want to raise the truck a bit without going full lift kit, the level kit and same size blocks in the rear is an easy an cost effective way to do it. Dont go over 2" in the front or it will sit nose high.
