Re: Any pump gas B1 motors out there?
[Re: LUMI]
#1712566
12/19/14 04:51 AM
12/19/14 04:51 AM
Posts: 43,273 Bend,OR USA
Cab_Burge
i have a full pumpgas streetcar
B1 originals, B1 Intake, Venolia 4.5 pistons, Callies 4.77 Crank, 6.8" H beam Rods, Koleno KP440 Block, 1270cfm AED Max Pro Dominator, Crane Mec Roller 320/328deg 114 disp angle int .79 ex .76 CR10.69 TTI 2.0/ 2 1/8 /3.5 Headers
original B1 rockers broke last summer at 800/275 lbs i will try T&Dīs original shaft ones next summer
That is quite a bit bigger C.I. than I'm thinking of building, do you mind sharing your results if you dyno tested or ran it at one of your tracks over there? I hope so Thanks
