I don't know if this has been beat to death but I'm putting together another stroker with some parts I have. It will be 550-600 HP. My other stroker had 500 HP and a cast crank and scat H beam rods. My question is what is the best crank and rods to use? It will be a 4 in with a 6.123 rod with .984 pin or at least what I'm planning on. The pistons are flat tops with I think 1.46 compression height, they are weisco forged pistons. I am thinking either Molnar, Bpe or K1. Rods I have looked at are scat, K1 or molnar.
I guess I am looking for input on what you guys like or dislike and have used or want to use. Thanks Craig
