Q.#1...If an oil priming rod is used after a re-build and ran clockwise rather than counter-clockwise (like a 383 should), could the new oil pump be damaged?
Q.#2...Oil pressure at start-up was 40-42 psi and stays there even when warmed to operating temp. Is this adequate oil pressure? The oil is 10W40 and the pump is standard OE.
