Well, i was messing around with the pistons last night, sprayed them down with penetrating oil. After moving the rod back and forth, I noticed that the entire wrist pin is spinning in the piston, and the rod seems stuck to the pin.
Are the pins pressed into the piston and not supposed to move? Even if I free the pin from the rod, is the piston now junk? Ugh!!
