I disagree.
Missed the heads did you?
You're looking at LA based heads, he's running Magnum based.
hmmm....
The cylinder heads are Indy T/A's, a variation of the Edelbrock casting with offset intake rocker arms for a larger port cross-section.
His Maggies are not going to run 60 hp more than the Indy heads with 60 less inches and a similar bottom end.
Sorry, it's not going to hit 400 rwhp.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
