Decided to try the install myself since removal was so easy. I got the glass and gasket from an '86 or '87 so I should be good there.There was a rubber bead/rope that ran the length of this groove you see in the gasket. But even without it the glass was in there nice and solid. I pulled it with the gasket on the glass. Do I install it the same? And can I get just the rubber bead that goes in that groove from somewhere?
Also I took some advoce.from on here and tinted it with the glass out of the car. It was fairly easy.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
