If you have 90\10s or 3 ways on the front and single adj on the back, you can only afford to buy 2 shocks, which one do you replace
If your car doesn't have a wheelieing problem I would go with rears. If it's pulling the wheels a lot then I would want fronts. But I don't think with your gears you have a problem in the front.
That was a very nice way to tell me Im slow. Ok, lets say i start spraying a 150 shot on it. Then fronts or rears?
Your answer better not be " you'll still be slow"
Don't you only have 3.54 rear gears? I would put the 3 way on the front and still get rears for nitrous use. It should go bottom nines on the hit, that would be fun to see at drag week.
Brett Miller W9 cnc'd heads STR Chassis fabraction
