They are known to feather outer edges--The Goodyears are the worst for that--other brands do it much less--massive constant rotation with x -ing is my answer works! usually every 3500 miles or so--change direction on the tires --it really helps The Wranglers that came on mine were pure t junk Michlin is the way to go
And see that last set of Wranglers that I had on my 1-ton went for 80,000 miles and my truck is always loaded up. I've also have great luck with Michlins too but the last set I have on it cupped out really bad when my LBJ's went out. Pissed me of cause they were fairly new.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
