Quote: I wouldn't even consider the cyl heads until I was sure the intake wasn't the problem. In your case the intake is the problem. That's a fact
Consider this... Lets say your new heads flow 280 (big number) but your stock intake will only let you have 230 cfm of that. Do you think that is the recipe to hp happiness?
