Usually coilovers are okay as long as they tie into the stock mounting points. Check the rules to be sure.
Most of them equate to the 4 K member bolts still mount the K, the UCA uses the stock mounting points, and the shock mounts to the stock point on the body which will need to be braced to support the weight of the car.
