^^^^^^ Do you have a Pic of those on the block?
i will, i have them on my mock up block on an engine stand. i plan on documenting this process a lot with pics. i think with mild mod to the headers, they will work well on my build. i am making a bracket to move my alt. up and out 1 inch.
an a/c compressor is most likely out of the question. my hot side will run to the front even with the oil pan rail under alt. and between oil filter adapter and frame then s up to turbo on pass. side up by radiator..
the driver side will run up pan rail where a/c comp. goes, then around belt, then 90* turn in front of balancer up to same turbo
my hot side will be 2.25 stainless with a flex pipe on each bank . the downpipe will run parallel with valve cover between VP and inner fender turned down to follow trans. dip stick tube to under the car
also remember, i have rack/pinion tube front end with home made mounts
