this wiring harness has 2 ground wires for headlights on both sides of the radiator
If you touch the jumper to one of the ring terminals that is bolted to the rad & the lights are OK then with your meter on 20 V scale touch the positive meter lead to the batt neg and the neg meter lead to the rad & see how many tenths you show. then rad to rad support then rad support to batt neg till you find the poor/loose continuity (it'll show too high of voltage on the meter)
