I have a 87 D250 utility truck. change wiring harness to a 85. I have ground problem with the lights. when lights are on; lights fluctuate like there is a loose ground. checked grounds, battery to engine, bat. to body, wiring harness, all are tight. when I run a ground wire from bat to negative head lite wire, light is bright with no fluctuation
