Quote: Thanx!! Meziere Remote Mount Water Pump, mounted on a bracket that goes from the k-frame to the core support, under the radiator. I made the motor plate
I dont understand this part- mounted on a bracket that goes from the k-frame to the core support, under the radiator
sorry Steff,
I looked to see if I had a pic of it and I don't. I can post one later when I get home from work.
