x2 on the factory service manual.
Also, if you pull the pot coupling apart, mark the orientation or indexing. If it is re-assembled 180 degrees off, it will be impossible to center the steering wheel. The coupling is easy to rebuild with a simple kit and its a good idea to get it cleaned, checked and re-lubed.
