79powerwagon:
It's not as big of a job as it looks.
I did it on my 360 Magnum and had the same initial reaction as you. Turned out, it wasn't so bad.
Yep, just take a good hard look at it and use you imagination. You don't need to remove the accessory mount. I've done it several times on the V8's and once on the V6
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
