Look for stock replacement pistons from Badger or Federal-Mougal.
The trick here is to pay attention to the pistons height. If you can not find a slug slightly taller, have the machinist deck the block or heads a bit. You'll have to crunch numbers with him to finalize the exact comp ratio.
