On my '96 the connector (blue if I recall) was taped up near the drivers side kick panel. Wasn't easily seen at first.
That's where it was on our 05 hemi durango and the pigtail was in the glove compartment.
99 Ram.... 05 Durango.... Love ya man!!, but those rigs are so different you might as well said toyota tacoma!
guy on the 96 is a close 2nd.... lots of changes. Unfortunately it clouds my mind so i might not be of any help either as I can't remember when they started the "blue" connector deal... "IF" your truck does have it, it will be attached to the top of the bulkhead connector under the dash on the drivers side, just to the right of the E brake pedal...in between the ebrake and brake pedal.... Hope this helps in some way
