look at the plug thats in there and zero in on the ground strap. you want the color band to be midway up the strp. close to the electrode means your too cold. to close to the threads means too hot. you want midway
yes, there was a excellent recent thread(with pics ) detailing where to check on the plug for heat range & where to check for mixture. Might do a search or check the archives. I'm becoming convinced that I absolutely need an LM-1 innovate wide band meter with an rpm converter.
