Quote: I use the 631 with a Meziere water pump with a motor plate and never have any issues(my pump has just the 2 ports that bolt on to the plate/block.. if your pump has the blades beyond the flat of the mount area you need the 631 cover
Mr. P Body - Do you have a part number for the Meziere pump you use? I looked at their site & did not see anything listed for the short deck R3 bolt pattern.
I did find a couple P4876632 covers for sale, about $400. That looks to be the easiest way to go. Thanks
