This is living proof on how much power a pump gas motor can make with decent parts What bore and stroke did you use on this build? It looked like the motor wasn't done making power at 7000 RPM I normally pull the motors until I find peak HP
I see VP110 listed on the dyno sheet so that's NOT pump gas.
Oops, your correct
