I stretch out the holes a bit with some spreading pliers to get the rubber a bit flexible, lube them up and go at it. I run the threaded portion in through one of the "side" holes, and then get the rest over the head. Have fun!
I just did this. Took some needle nose pliers and strectched the holes a little. Applied some grease to the boot openings and squeezed it through. I took a little chunk out of one of the side openings (it split slightly) but it doesn't seem like a big of a tear that it would let gunk in. 3 more to go...
