Quote: Eddie is not down on power...........he has the timing pretty soft and it struck the tires today and his 60ft was 12 numbers off from the 8.80 pass.
It has two 90mm drive by wire GM throttle bodies on it with the Holley EFI.
It has only 3 track passes on it with a new system and running .80s.................not bad
Monte
I agree. He's doing what it takes to win his class. This is a marathon not a sprint.
