Should be easy to spot a 727 with a 203 adapter in a pile of transmissions if they have some. The bolt pattern is fairly unique. If not like you mentioned look for the big nut on the 75-79's. If California wasn't so far away from Canada I would give you one I usually throw them in the scrap pile.
