Frames and pans are the same.
Boxes that spring perch hangs from is different between Dodge and Plymouth.
Inner wheel houses are the same between Dodge and Plymouth and 4-dr and 2-dr. Outer wheel houses are the same between Plymouth 2-dr and 4-dr but are different than Dodge. Also Dodge outers are different between 2-dr and 4-dr un-like Plymouth.
Also rear cross member is probably different. 68 has a round hole for the fuel tank filler tube and 69 is probably oval.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, .
Moparmarks Parts & Restorations
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/motormangj@gmail.com
