Why are you shifting at only 56-5800? A 250ish @ .050 cam in a 440 should be shifted about 1000 rpm higher. Also, you mentioned swapping to a 1.6 rocker (assuming roller), but what are you running now?
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
