Read the article, you want to feed the paint back first with #7 glaze. This old school product is rich in polishing oils that soak into the paint. Once that has been done you can then use a compound. Trying to compound out dry and faded paint right off the bat is not the way to do it safely. It's only original once and you have one shot to do it right
