I just ground through the front welds on the plate and bent it down just enough to slide it in. Took about 20 minutes. I'm going back out to weld it up now. It should be undetectable from original once done, except for that big sway bar being in there. Firm Feel has 2 available, I used the smaller of the two, which I believe is 1 1/8th". It's still significantly larger than the stock one.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
